Tamiya Panzer II
gibbs
Tamiya Panzer II
Postby gibbs » Fri Oct 12, 2012 1:11 pm
With the King Tiger finished I've decided on this for my next project, although I am looking to do this kit serving on the Polish front rather than North Africa
The sprues
My little corner of the internet
https://thearmourfarm.wordpress.com
Re: Tamiya Panzer II
Postby TRDG » Fri Oct 12, 2012 1:28 pm
Thats a nice build as well, lots of figs I see to, should be a good one to play with on your build, smaller and quite different than the other cats you have posted about so far. Any clue on camo, maybe a winter type pattern might look good??
Cheers, onto your next model build and I'm looking forward to it!!
gibbs
Postby gibbs » Fri Oct 12, 2012 6:05 pm
It's going to take alot of sanding to prep the hull to receive it all but I'm hoping it'll be worth it in the end either that or I've finally lost the plot
gibbs
Postby gibbs » Thu Oct 18, 2012 7:04 pm
I small update for this build I've got the wheels cleaned up ready to be painted and fitted
gibbs
Postby gibbs » Fri Oct 19, 2012 12:50 pm
A slight change of plan as the plastic card arrived this morning so I made a start on the interior instead
gibbs
Postby gibbs » Tue Oct 23, 2012 2:57 pm
I realized that I have been a bit lax in updating here and for that I apologize since my last update the
wheels have been fitted and painted and the interior has been fitted and painted
despite all that work you only see a tiny bit of it all
While it is by no means accurate due to there being a crew position missing although I may add it in but that depends on how the turret sits I'm hoping that it gives a general idea of what is meant to be there
gibbs
Postby gibbs » Thu Oct 25, 2012 6:59 pm
Time for another update on this build the upper hull is painted and ready for permanent fitting when I get the tracks on and work has started on the turret
gibbs
Postby gibbs » Mon Oct 29, 2012 7:22 pm
A large amount of work has gone into this over the past few days including modification of one of the figures
gibbs
Postby gibbs » Wed Oct 31, 2012 8:08 pm
I've been working on the figure and have cleaned up the legs and fixed the shoulder so these pictures should give an idea of the final look and positioning I just need to finish gathering some references to make sure I get the details right.
gibbs
Postby gibbs » Tue Nov 13, 2012 6:45 pm
Whoops I am behind on updating this :oops: sorry guys
Not alot has happened the past week or so as I've been working on a assignment for college and lost my bench to paperwork but that was handed in yesterday all 96 pages including research.
but since the last update the tracks are on
and I've done a bit more work on the figure
