GURPS MWF: OPERATION "JUST BECAUSE"
All things Role Playing Games
Moderator: Frank
Chevalier Errant
Private First Class
Private First Class
Re: GURPS MWF: OPERATION "JUST BECAUSE"
Postby Chevalier Errant » Wed Jul 01, 2015 9:34 am
EVERYBODY OUT! JUMP OFF ON GIBB'S SIDE!!!
Postby josta59 » Wed Jul 01, 2015 11:00 am
Grayson opens the door and climbs out of the truck's cab and heads toward the beach, weapon at the ready, watching for enemies. He joins the others, making sure Cristobel is ok and headed toward safety.
Postby Frank » Wed Jul 01, 2015 1:50 pm
Gibbs throws himself off the truck and starts running, trying to keep the truck between himself and the shooters. He scans the ground in front of himself, looking for any cover to form a defensive position to hold off the bad guys.
Postby josta59 » Wed Jul 01, 2015 1:52 pm
Grayson says to Gibbs, "Hey there. Guess there wasn't much point in you getting in the truck, huh?"
Postby Frank » Thu Jul 02, 2015 11:32 am
Gibbs glares at Grayson and saves his breath for running.
Chevalier Errant
Private First Class
Private First Class
Postby Chevalier Errant » Thu Jul 02, 2015 3:35 pm
Dutch mskes sure Cristobel jumps off, grabs the pridoner and jumps off with jom, dragging him away from the truck and towards the beach while keeping the truck between himself, the prisoner and the bad giys.
GRAYSON@ GIBBS! LAY COVERING FIRE!!
Postby josta59 » Thu Jul 02, 2015 3:40 pm
Grayson lays covering fire.
Lucky Luke
Postby Lucky Luke » Fri Jul 03, 2015 10:51 am
Grayson exchanges fire with the thugs hidden behind the dunes.
Gibbs is leading the way, Cristobel is the next and Dutch is dragging the crying prisoner.
Some bullets zing near but nobody is hit.
Grayson is 10 meters from the truck and he sees the flames intensify and grow in height...the heat is playing havoc with the IR goggles...
V6!
Luca
"I'd rather be lucky than good any day."
Postby josta59 » Fri Jul 03, 2015 11:07 am
Grayson backs away toward his group, spraying bullets as he goes.
Postby Frank » Sat Jul 04, 2015 2:33 pm
Gibbs is too busy running to change to his assault rifle, so he draws his Biretta to add to the covering fire. He knows the chances of hitting anything are remote but just seeing they are being shot at should make the bad guys think twice.
Return to “RPG Corner”
