STAW Stealth Mission
Storage area for non-Member made Game Scenarios
Moderators: Hagen, Frizzenspark
Postby Whiterook » Thu Nov 03, 2016 7:50 pm
Mission: Investigate reports of a secret enemy research facility in this sector.
Needed: At least Four Obstacle Tokens (Optionally one of them may be a Planet.)
The "Echo" and "Actual" tokens from the IRW Valdore expansion.
Player 1: 50 SPs. You may have exactly 1 Ship that is able to Cloak (as a default action or from an Upgrade). This ship begins play with a Cloak Token
Player 2: 90 SPs.
Player 2 places all Obstacles. Then place the "Echo" and "Actual" tokens face down, no more than one on a given Obstacle. Player 2's places all ships first, ships begin within Range 1 of any obstacle. Then Player 1 may place his ship on any edge of the Map.
Special Rules: Player 2 cannot fire upon or target Player 1's ship with abilities until the ship is detected. Player 2 gains the following special ability.
Action: If you are within Range 1 of a Cloaked enemy ship, OR Range 2 if your ship has a SCAN token, forgo your normal Attack to roll 1 Red Die (roll 2 Red Dice if you are both at Range 1 AND have a SCAN token). On a HIT the Cloaked ship has been detected, and for the remainder of the game may be attacked as normal.
Player 1 gains the following when within Range 2 of an obstace with a facedown Echo/Actual token
Action: If you are within Range 1 of an of an obstace with a facedown Echo/Actual token, OR Range 2 if your ship has a SCAN token, forgo your normal Attack to roll 1 Red Die (roll 2 Red Dice if you are both at Range 1 AND have a SCAN token). On a HIT or CRITICAL flip the Echo/Actual Token faceup.
Goal: Player 1 wins by locating the Actual token and then returning to starting point.
Player 2 wins by preventing Player 1 from achieving that Goal.
Return to “Equipment Locker”
