Simple Chanceless Tactical Wargame
Postby josta59 » Sun Jan 04, 2015 9:27 pm
Tonight I started thinking about how to design a simple wargame that is pure tactics, no chance involved. I want my kids to be able to play it, so it needs to be simple and fun. And since it's pure tactics, it's bound to be good for their brains.
I want to put down my rudimentary thoughts to get some feedback, and I'll add more ideas as they come to me. Also needs a name.
Figures (e.g., chess piece) represent a soldier, squad, tank, plane, boat, etc.
Movement:
Players take turns moving half their available units each turn.
Small scale: Movement is 2 handspans and range is limitless.
Large scale: Movement is the length of an index finger, fire range is 2 handspans.
Huge scale: Movement is one space orthogonally or diagonally on a chess board.
Attacking:
Any unit with LOS (and in range) may attack once per turn.
Objects (or marked squares on a chess board) may block LOS.
Each figure has a stack of 10 coins representing hit points.
All attacks cost at least 1 coin, accounting for counterattacks and fatigue.
Attacking a figure with an equal number of coins removes 2 of the target’s coins at a cost of 1 (see matrix).
Attacking a figure with half or fewer coins removes 3 of the target’s at a cost of 1.
Attacking a figure with twice as many coins removes 1 of the target’s at a cost of 2.
Attacking a figure with more but fewer than twice as many coins removes 1 of the target’s at a cost of 1.
Attacker A attacks defender D:
Terrain modifiers:
A figure attacking from rough ground or attacked in rough ground gets a result of -2 reduced to -1.
Advanced rules:
Different types of figures represent different types of units (e.g., infantry, tanks, artillery, etc.) with different range of fire and different susceptibilities to damage, decided by the players.
Leaders: Players may move half available units plus all units within a handspan (small scale) or knuckle (large scale) of a leader figure (e.g., the king).
Armor save: After every attack, roll 1d6 for the defender. A roll of 5 or 6 saves 1 coin for the defender only.
Re: Simple Chanceless Tactical Wargame
Postby josta59 » Mon Jan 05, 2015 12:08 am
Playtesting has been fun tonight. The game would definitely be more fun head-to-head, of course. It's my best game design yet, which isn't saying much.
I think the matrix needs some small adjustments, which I didn't realize until my game was nearly over. But I think the basic concept is solid.
You definitely have to use markers to reflect movement and firing, or you'll get lost very fast.
I started with identical forces, and things got interesting when I ended up with more units on one side, but they were at half strength, vs a smaller but stronger force. It got lop-sided quickly, which made it interesting.
I'd post a picture, but it's just chess pieces, coins, and random objects on my dinner table. Not much point.
Postby Whiterook » Sat Oct 03, 2015 8:21 pm
I like the exhaustion concept with the coins...simple and elegant. I've never seen the use of fingers and knuckles as measuring parameters....interesting....I can see that as a good mechanic for kids, and would think that brings a great elements fun and amusement to them.
I gravitated to the Leaders, and would like to see that explored more in-depth. Again, as a learning tool, I think that brings invaluable lessons in structure and the price of leadership.
Do you have Firegroups built into the system?
Postby josta59 » Sun Oct 04, 2015 8:25 am
Heh, I've had different threads in different places at different times as my thoughts have evolved. This is a pretty early post with concepts that became part of Showers of Blood.
To answer the question, yes...sort of. I've played SoB various ways. It's a flexible system, and you can decide prior to a game whether units will represent individual soldiers or teams. I've posted AARs doing it both ways. Both were very fun. When playing man-to-man, there's no mechanic tying them together. But it sure helps to play them as teams, as in real life.
